The suite's software includes the NI Signal Analysis Toolkit for Fixed WiMAXwww.cechina.cn, which works with RF vector signal analyzers (VSAs), and the NI Signal Generation Toolkit for Fixed WiMAXwww.cechina.cn, which works with RF vector signal generators (VSGs). Combined with high-performance multicore processors, PXI Express-based measurement systems for WiMAX which are built on this software package can help engineers complete error vector magnitude (EVM) and spectral mask measurements two to three times faster than leading traditional box instruments. For automated test applicationsCONTROL ENGINEERING China版权所有, the suite offers programming APIs for signal generation and analysis in programming environments such as the NI LabVIEW graphical system design platform and LabWindows(TM)/CVI ANSI C development environment as well as ANSI C. While signal generation and measurements are compliant with IEEE 802.16-2004 (also referred to as IEEE 802.16d) specifications, engineers can use the software-based approach to customize measurements. Because the Signal Analysis Toolkit for Fixed WiMAX provides access to both the raw I
