资讯 > 英文资料文献
Bluetooth RF transceiver module
www.cechina.cn2009.09.24阅读 7262
        Wago Corp.'s 750-644 Bluetooth RF-Transceiver module provides fast, bidirectional控制工程网版权所有, wireless communication between I/O nodes. Within 10 ms, the 750-644 exchanges data up to 1,000 m (line-of-sight) or 100 m (within buildings), providing Control engineers with a cost-effective wireless solution. It is ideal for a wide range of applications such as robot controls, high bay warehouses, and renewable and traditional energy applications such as oil field
s. One 750-644 master can communicate with up to seven slaves on a Personal Area Network (PAN), also known as a piconetCONTROL ENGINEERING China版权所有, via Bluetooth 2.0+EDR radio technology. Slave-to-slave data transmission is possible indirectly through the master. The module offers robust communications with frequency hopping procedures and adaptive transmitting power technologiesCONTROL ENGINEERING China版权所有, which allows the piconet to co-exist with other radio technologies found in industrial applications. The data exchange can be encryptedCONTROL ENGINEERING China版权所有, maximizing security.
Wago 750-644 Bluetooth RF-Transciever module
Wago 750-644 Bluetooth RF-Transciever module was introduced for cost-effective I/O-based communications, company says.
        This is the newest addition to the fieldbus-independent Wago-I/O-System that supports prevalent fieldbus technologies: EtherNet/IP, Modbus TCP/IP, Profibus, DeviceNet, and CANopen. The Bluetooth module works with all standard fieldbus couplers/controllers found in the Wago-I/O-System, more than 300 analogwww.cechina.cn, digital and specialty modules. Configuration of the 750-644 is easy with Wago-I/O-Check 3 software. Wago-I/O-Pro programming software provides function blocks that make the module's use easier. The module carries eight on-unit LEDs for on-site diagnostics of interference, signal quality and timeouts. The 750-644 also features an SMA socket for Wago's 758-912 antenna, data contact, and power jumper contacts. It is available for immediate delivery.
标签:Control,
