资讯 > 英文资料文献
How and when to fold an IT project
www.cechina.cn2009.09.23阅读 2847
        Many manufacturing IT projects do not finish, not necessarily because they failed, but because of changing requirements, changing business conditions, company mergers, or changes in products and processes. It's important to know when to fold a projectCONTROL ENGINEERING China版权所有, but it is equally important to know what to do when you fold a project.
        A manufacturing IT project contains more than just software. Any projectCONTROL ENGINEERING China版权所有, wheth
er it's a PLC programwww.cechina.cn, DCS programwww.cechina.cn, MES system, SCADA system, HMI system, integration projectCONTROL ENGINEERING China版权所有, or a combination of these, will have: requirements, designs, test plansCONTROL ENGINEERING China版权所有, test cases, common libraries, documentation and coding standards, and other project artifacts. The project artifacts still have value because they represent the intellectual capital invested in the project that can be captured and made available for future projects.
        Typically, most project artifacts are kept only on desktop systems. At some stage in the projectCONTROL ENGINEERING China版权所有, these artifacts are copied to the target system or to a configuration management system. This is a risky approach because information will then be lost when the project is stopped. This is especially true if the project work is performed by contractors. As they will start looking for the next consulting opportunity once the announcement is made that the project is cancelled. Getting their attention and time to correctly document and save all of their work will be difficult, if even possible. For many projects, once the announcement is made控制工程网版权所有, all outside contractors will be off the site by the end of the day.
        The best rule for any project is to capture all project artifacts in common storage and, if possible控制工程网版权所有, place the artifacts in a Controlled configuration management system. If you are following the approach of engineers and programmers working in a local sandbo
标签:Control,
