资讯 > 英文资料文献
Economical power monitoring devices
www.cechina.cn2009.10.19阅读 2239
Siemens Industry Sentron PAC power monitoring devices range from traditional basic monitoring to intermediate power quality monitoring capabilities
        Siemens Industry Inc. introduces the new line of Siemens Sentron PAC power monitoring devices. This cost-effective line of meters ranges from traditional basic monitoring to intermediate power quality monitoring capabilities. The meters have bright LCD screens and can be configured through menus on the front or using free software for remote configuration. They meet all ANSI/ UL/ IEC requirements for safety and accuracy. The PAC3100 meter is an “amp volt plus” meter. Designed to replace analog and amp meters控制工程网版权所有, it also offers advanced featureswww.cechina.cn, such as Modbus RTU communication, a large display, and KVA/KVAR monitoring capabilities. It measures import and export energy and 25 other parameters. It is well-suited for sub-billing or cost allocation in commercial or industrial applications. When combined with supervisory systems, the meter cost effectively meets government EPAct and LEED requirements. It measures over 50 parameters and has a faster sampling rate for applications that require information about the state of the electrical system. Multiple communication protocol capability makes it a good choice for commercial and industrial systems. Optional communication modules for Modbus RTU and Profibus DP and can receive data from two independent supervisory systems—the Modbus TCP and the Modbus RTU. It enables users to set limits or alarms for voltagewww.cechina.cn, current控制工程网版权所有, power factorwww.cechina.cn, and frequency. The PAC3200 does not require transformers when used with systems of 690 or fewer volts and offers a 22-65 V dc Control power version for industrial systems with 24 V dc control power circuits.
标签:Control,
