特点: MB770 产品规格 CPU 支持 快取 芯片组 前端总线 系统内存 视频 DVI LVDS 网络 音频 LPC I/O Secondary I/O USB Serial ATA IrDA IDE Interface FDD Interface 看门狗 键盘鼠标 扩充槽
·VIA CN700 芯片组 VIA Eden-V4 CPU
·CPU 速度:最高1.8GHz,1GB DDRII 内存
·Integrated VGA, 支持18/24-bit LVDS LCD
·板载10/100 LAN1, Optional Gigabit LAN for LAN2
·6 x USB, 2 x SATA 串口
·4个 COM 串口, 看门狗
·板载PCI和 Mini PCI 槽, Optional TV out
VIA Eden-V4 / VIA C7, 400MHz ~ 1.8GHz
128KB L2 cache控制工程网版权所有, CPU integrated
VIA CN700 / VT8237R+ Chipset:
North bridge: CN700 / 567-pin HSBGASouth bridge: VT8237R+, 539-pin PBGA
400MHz / 533MHzBIOSAward BIOS, ACPI supported
One DDRII DIMM socketSupports up to 1GB DDRII SDRAM
VIA CN700 integrated128-bit Unicrhome Pro 3D/2D controllerSupports 16/32/64MB frame buffer size
ID393 card: VIA VT1632A (with DVI edge connector to be located above the USB stack connector)
Supported by VIA VT1631L for 18-bit or 24-bit dual channel LVDS
LAN1: Built-in VT8237R+ 10/100 LAN MAC + VT6103 PHYLAN2: Optional RTL8110S-32 Gigabit LAN controller (MB770F only)
VIA VT8237R+ built-in sound controller + AC97 Codec ALC6555.1 channel (Line-out, Line-in, Mic)
Winbond W83697HGCOM1, COM2 (RS-232), FDC 1.44MB (Slim), IrDA控制工程网版权所有, Hardware Monitor ( 2 thermal inputswww.cechina.cn, 6 voltage monitor inputswww.cechina.cn, 1 chassis open detectionCONTROL ENGINEERING China版权所有, 2 fan headers)
Fintek F81216D for COM3 / COM4 (RS-232)
6 portswww.cechina.cn, USB 2.0 ( 4 ports onboard, 2 via pin header)
2 portswww.cechina.cn, support RAID 0, 1
Pin header on board
Two channels; supports Ultra DMA 33/66/100/13340-pin box-header x 1 (IDE1), 44-pin header x 1 (IDE2)
Slim type connector supports slim type FDD drives
Generates system reset; 256 levels
PS/2 type connectors
&nb
