资讯 > 英文资料文献
Seeking Certification CSIA-approved Auditors are Here to Help
www.cechina.cn2009.08.24阅读 2252
        Businesses looking for CSIA certification or any other internationally recognized standard know they must jump through a variety of hoops and withstand a great deal of trepidation before becoming certified. To get through this process, some organizations contact the auditing agency for guidance and ask questions regarding the process. Other organizations, howeverCONTROL ENGINEERING China版权所有, prefer to go it alone and take their chances.
      &nb
sp; The two independent CSIA-authorized auditors, ASR (American Systems Registrar) and Exotek LLC encourage you to contact them prior to going through the actual audit. They’re available to assist you控制工程网版权所有, and can help prepare you before, during and after the audit. Extensive use of this support has been found to significantly help those seeking certification.
        When auditors conduct a CSIA certification audit控制工程网版权所有, the integrator should be prepared for an intensivewww.cechina.cn, day-long review of all aspects of your business—general managementwww.cechina.cn, strategic planning, human resources, project management and methodologies, project development life cycles, technical management and infrastructure support activities, quality assurance processes, finance, and business development. The agenda for the day will follow the Audit Report, based on the CSIA Best Practices & Benchmarks document.
        To help avoid the things you should not do if you are seeking certification, ASR and Exotek have identified three things that often indicate a high probability of not passing the first time:
        1.Lack of top management support and direction;
        2.Failure to perform self audits; and
        3.Misinterpretation of requirements
        Following are some suggesti
标签:Control,
