资讯 > 英文资料文献
How to Choose a Controller
www.cechina.cn2009.09.17阅读 12353
        Like the cereal aisle in the grocery storeCONTROL ENGINEERING China版权所有, the number of Controller vendors and individual controller models available can present a daunting choice. Faced with so many options控制工程网版权所有, many engineers simply go with what they or their predecessor have used before. But that may not be the best choice for your application. So Control Engineering asked application engineers and other experts from a dozen controller vendors to offer some of their expertise r
egarding what application-specific controller features to look for. Here's a taste of what they had to say, arranged by application type. Online, you'll find expanded essays and links to customer case histories and whitepapers that provide more detailed instruction. You also can respond online and tell us about your applicationCONTROL ENGINEERING China版权所有, or post a question to our application experts. Scroll down the home-page at www.controleng.com this month to find the link to the current issue, or visit the magazine archives there anytime.
        Packaging Machine
 Packaging machine
        Packaging machine
        Packaging machines range from all mechanical (GEN I) to hybrid servo and mechanical (GEN II) to all-electric driven machines with full servo designs (GEN III). GEN III machines are designed from the ground up around what servos and controls can do to electronically synchronize the entire machineCONTROL ENGINEERING China版权所有, without the need for a line shaft and complex fixed mechanical cams. GEN III machines are virtually all electricalwww.cechina.cn, with significantly fewer mechanical parts and greater functionality, such as running multiple products and supporting automated changeover. The all-electric system typically runs at higher speeds and is responsible for electronic synchronization, complex camming, and high speed registration along with advanced high speed robotics capabilities. Therefore, it will require a faster c
标签:Control,
