Conventional ac induction motors are universal in application to the point that you would be hard pressed to find an industrial facility or even a residence without one. However控制工程网版权所有, in this energy conscious age, manufacturers are hitting the limits of efficiency in this design. On the other hand, permanent magnet (PM) motors can offer higher efficiency levels than induction motors since they have no I2R losses in the rotor.
&nb
Rotor construction of ac PM motors is much different from traditional induction designs, but eliminating the rotor copper losses gives PM motors a big efficiency boost.
attractive packages with smaller frame sizes and weight for a given horsepower rating weighed against conventional induction designs. On the other hand, induction motors are still generally less expensive and more able to withstand rough applications.
Two rotor types
Like their induction motor counterparts, ac PM motors use a wound stator, but that's where the similarity ends. PM motors have the magnets attached to the rotor控制工程网版权所有, either on the surface or embedded inside. Consequently控制工程网版权所有, there is no rotor current控制工程网版权所有, which reduces copper losses. This is the main source of the efficiency gain.
The differences between surface mounted permanent magnet (SPM) and interior
