“The typical Broadway show today requires the use
Hudson manual control and drive rack. In the left baywww.cechina.cn, the operator manual control station includes selectors per effect for local, off, and auto mode section; a single set of jog control including forward, reverse, and speed pot operators; and a Mitsubishi E1101 HMI. In the right bay is a six-axis drive panel including Mitsubishi E720 5HP drives; Sprecher + Schuh contactors for motor and brake control; and a Beckhoff BK7150 CC-Link coupler moducle with digital input, digital output, and encoder input modules.
Even if you have never been to a Broadway show, you’ve probably seen Hudson Scenic Studio’s work. They provide the automation systems that lower the Times Square New Year’s Eve ball, as well as scenic fabrication, automation, and lighting for themed casinos, restaurants, and amusement parks.
The two main uses of automation in Broadway shows are to fly scenery in and out from above and to bring things on and off stage. “We primarily use ac motors to power winches to drive the machines that handle this kind of workwww.cechina.cn,” says Adomanis. “But we also use different motion control typesCONTROL ENGINEERING China版权所有, like hydraulic and pneumatic. Our business is really ab
