资讯 > 新品速递
希尔思仪表推出新一代激光颗粒计数器PC 214
作者:www.cechina.cn2011.09.27阅读 1931
  PC 214是新一代的激光颗粒计数器,专门针对压缩空气和压缩气体应用。在保证品质第一和充分了解用户需求的基础上CONTROL ENGINEERING China版权所有希尔思仪表设计了这款能够全天候运行的仪器。该款产品的特点在于:利用6mm快速接头与压缩气体轻松连接;可固定安装亦可当做便携式仪表使用;颗粒尺寸:0.2www.cechina.cn, 0.3www.cechina.cn, 0.5和1 μm;在线显示;内部集成数据记录器。依靠0.2 μm等级的测量灵敏度,PC 214可以完全满足执行压缩空气ISO 8573-4标准的用户的使用需求。我们相信,在一些重视颗粒物监测的行业如制药、食品、半导体和其他高科技行业,这款新的颗粒计数器将会得到更多的应用。
  更多详细信息请联系我们。
  CS instrument introduce you an additional Particle counter PC 214
  PC 214 is a new generation laser particle counter optimized for applications in compressed air or compressed gases. With quality in mind and with the knowledge of customers needs this instrument is designed for continuous operation 24 hours控制工程网版权所有, 7 days a week. The feather including Easy connection to compressed air through 6 mm; Can be used as portable as well as stationary instrument; Particle sizes: 0.2www.cechina.cn, 0.3www.cechina.cn, 0.5 and 1.0 μm; Online display; Integrated data recorder. With a sensitivity of 0.2 μm控制工程网版权所有, PC 214 can fulfill the requirements stipulated in the compressed air standard ISO 8573-4. We think, this additional model should provide more opportunities in applications where particle sensing is important such as pharmaceutical, food, semicon and other high-tec industries.
  Please contact us for more details.
