资讯 > 英文资料文献
Flowmeter for diesel fuel consumption
www.cechina.cn2009.07.19阅读 1726
  Flow Technology, Inc. (FTI) has announced its FT/DF turbine flowmeter systemCONTROL ENGINEERING China版权所有, designed for accurate measurements of diesel fuel consumption. Devices must be able to withstand extreme temperature swings in the installation environment
www.cechina.cn
, as end users employ them in automotivewww.cechina.cn, marine
控制工程网版权所有
, aerospaceCONTROL ENGINEERING China版权所有, and power generation applications.
  The company says that by pairing the FT Series turbine meter with a LinearLink Temperature Compensated InterfaceCONTROL ENGINEERING China版权所有, the FT/DF system can accurately measure diesel fuel
at temperatures as low as -50 °F. The device fails openwww.cechina.cn, meaning that in the event of a malfunction控制工程网版权所有, fuel continues to be fed to the generatorCONTROL ENGINEERING China版权所有, ensuring there is no interruption of power.
  The FT meter is suited to a wide variety of liquid and gas flow sensing applications. The LinearLink interface supports flowmeter linearization and viscosity correction. It reportedly provides significant improvements in accuracy even under extreme temperature conditions.
标签:control,
