“The average daily flow at the facility is about 11 million gallons,” explains Dale Doerr控制工程网版权所有, Sheboygan Regional Wastewater superintendent. “If we have a rain event
控制工程网版权所有, Sheboygan Regional Wastewater monitored its pumping stations remotely with a SCADA system控制工程网版权所有, but the system was unable to detect motor load conditions. The facility turned to overload and monitoring relays to obtain real-time information." src="http://www.cechina.cn/upload/article/c6900e5f-a339-4fdf-800b-58cb370dec00/1.jpg">
With its pumps typically located 30 ft. below ground控制工程网版权所有, Sheboygan Regional Wastewater monitored its pumping stations remotely with a SCADA system控制工程网版权所有, but the system was unable to detect motor load conditions. The facility turned to overload and monitoring relays to obtain real-time information.
If a pump is partially restrainedwww.cechina.cn, the pump and motor would still run, albeit inefficiently, until the bi-metallic overloads eventually trip. This happens if current draw is sustained at a level above 115% full load amperage (FLA) for a period of time.
Lift station retrofit
With this motor issue in mindCONTROL ENGINEERING China版权所有, Doerr looked into using Eaton’s Motor Insight overload relay. Eaton explained that these relays would allow Sheboygan Regional to monitor its entire system including line, load, and motor from a headquarters location, thus avoiding the manual pump checks. With real-time data, maintenance personnel would only need to be sent to a location when data suggested there was a problem.
Sheboygan Regional agreed to be a beta site and retrofit its Indiana Avenue lift station with Motor Insight relays, remote displays, and Modbus communication modules on the station’s three 60 hp pump motors.
Impact of early detection
Soon after i
