To help reduce costs and improve machine efficiencyCONTROL ENGINEERING China版权所有, Serpa also collaborated with
Machine runs cases and trays
According to Serpa控制工程网版权所有, the P200 is the first case packer to be able to run cases and trays on the same machine. The machine collates the product to achieve the correct patternwww.cechina.cn, loads the product into the case or tray and seals and discharges it. The servo-controlled erector motion has two camshaft profile axes that drive a parallel-link arm. The arm picks up the case and erects it in the same area where the loading takes place. Because the loading and case erection occur in the same area, it reduces the overall footprint and maximizes the speed of the P200.
Using Rexroth servos helped simplify the overall design for easy access and a smaller footprint. For the P200, Serpa opted for Rexroth’s IndraDrive intelligent digital servo drivesCONTROL ENGINEERING China版权所有, IndraDyn servo motorsCONTROL ENGINEERING China版权所有, and a linear Ball Rail? system. The motion and logic was programmed with Rexroth IndraWorks software.
Instead of a mechanical drive, Serpa used Rexroth’s servo system to create an electronic line shaft with cam-profile movement. The P200 uses multiaxis synchronization with the ability to change motion profiles on the fly. Of the seven axes, four are synchronized using electronic cam shafts and three are point-to-point axes.
To achieve proper forming of the case, the erector and walking beam motion are tightly synchronized through SERCOS III communicatio
