资讯 > 英文资料文献
Safe Position Measuring
www.cechina.cn2009.08.12阅读 4172
        Safety is becoming an increasingly important topic in machine and plant construction. This has become evident in legislation and tightened safety requirements in national and international standards designed to protect human beings控制工程网版权所有, material assets控制工程网版权所有, and the environment.
        The goal of functional safety is to minimize or even eliminate the risks that can occur during normal or impaired operation of machi
nes or facilities. Here, safe position measuring systems are essential.
        The increased use of processors and programmable systems led to a revision of the EN 954-1 standardwww.cechina.cn, which had been in effect for machine construction since 1997 and was harmonized under the European machine directive. The EN 954-1CONTROL ENGINEERING China版权所有, with its deterministic approachwww.cechina.cn, was no longer adequate for the new requirements—a fact taken into account in its successor standardwww.cechina.cn, EN ISO 13849. This new standard includes the reliability of components and programmable codes similar to the IEC 61508, as well as the product standards derived from it, such as IEC 62061 for electrical drives.
        Particularly in mechanical and plant engineering, moving axes are a potential danger, inspiring increasing numbers of designers to integrate the mandatory safety functions directly in the drive. As a result, a technical trend has emerged toward purely digital transmission of position values from an encoder to the drive Control. This means that more complex electronic systems have become necessary in both the drive control and the encoders for precise position acquisition. The functions now available in machine and manufacturing systems and the concomitant stringent safety requirements, as defined in the relevant new standards, call for position encoders with entirely new solutions for safety-related applications.
 A modular approach to system design helps manufacturers of safety-related systems implement complete systems
标签:Control,
