资讯 > 英文资料文献
Safe Position Measuring
www.cechina.cn2009.08.12阅读 3652
        The challenges facing safe automation are reflected in the trends. The market wants overallCONTROL ENGINEERING China版权所有, compatible solutions from the sensor to the actuator. Ethernet is gaining ground as a universal communication system. As a result, the worlds of information technology and automation are growing closer together, which brings new challenges not just for safety, but for security, too.
        The trend is moving away fr
om exclusively centralized Control structures toward decentralizedwww.cechina.cn, independent cell automation and the mechatronic, modular approach that this enables. However控制工程网版权所有, networking several control systems must not increase the level of complexity. The future belongs to solutions that simplify user operation, while significantly increasing the level of flexibility.
        Along with the ongoing technological development控制工程网版权所有, standards also have a key role to play—a fact that is also reflected in the trends.
        There are currently a whole range of standards and directives on machinery safety that are entirely new or are due to replace existing editions. The two most important changes are the new Machinery Directive (2006/42/EC), which will come into force on Dec. 29, 2009www.cechina.cn, and EN ISO 13849-1, which will replace EN 954-1. To that, add DIN EN 62061 as a sector standard of DIN EN 61508. The general expectation is that the conversion process will not make the safety solution any easier for end users or system integrators.
        For the first time, methods will be available that permit a quantitative interpretation and verification of all the protective devices. Manufacturers need to design products with this in mind. Users need to see this change as an opportunity and try to promote active implementation.
        The new standards es
标签:Control,
