The smallest controller gain that can cause such an oscillation is called the ultimate gainPU. The period of those sinusoidal oscillations is called the ulti
P=0.6·P u
T I="0".5·T u
T D="0".125·T u
Forcing the closed loop system into sustained oscillations with a proportional-only controller reveals the process's ultimate gain PU and ultimate period TU. UnfortunatelyCONTROL ENGINEERING China版权所有, doing so can also cause dramatic and sometimes dangerous swings in the control effort and the process variable
Caveats
But even the Ziegler-Nichols methods aren't so straightforward in actual practice. Different PID controllers use different versions of the PID formula控制工程网版权所有, and each must be tuned according to a different set of tuning rules. The rules also change when:
•The controller is not equipped with integral and/or derivative terms;
•The process itself is inherently oscillatory;
•The process behaves as if it contains its own integral term (as with level control); and/or
•The process deadtime is very small or significantly larger than the process t
