Designed for energy applications, the Alstom Control system, Alspa ControPlant, requires the highest levels for reliability and availability for industrial applications. Alstom, a provider of energy management, power generationwww.cechina.cn, and rail transport systems, uses Alspa ControPlant as its distributed control system (DCS). The incorporation of Modbus and Ethernet Powerlink into the DCS makes the network a central part of the control system.
Alstom controller topology is run on a Fast Ethernet switched network.
The site network, mainly located in the control room, has few industrial constraintsCONTROL ENGINEERING China版权所有, and is generally based on a standard Fast Ethernet switched network. A fault tolerant ring topology ensures high availability. Determinism is not neededCONTROL ENGINEERING China版权所有, as standard Ethernet is used with IP protocol (TCP/IP and UDP/IP). The unit network has a speed of 100 Mbits/s or 1 Gbits/s and is made of fiber or copper.
Field networks and connected equipment are located at the field level and have the highest constraints. High-speed Ethernet meets the needs of new applications for the power market through increased network performance. To achieve this level of performanceCONTROL ENGINEERING China版权所有, Alstom selected two technologies, one without deterministic constraints and one with high real-time determinism require
