Industrial production line use of radio frequency identification (RFID) has become increasingly popular控制工程网版权所有, and the technology has become a hot-button topic. Why? Technology enhancements have advanced RFID far beyond its barcode counterparts—and gotten attention for return on investment (ROI) opportunities. While some companies may have argued that they could not afford to implement RFID into their operations, many now argue they cannot afford not to. Knowing the basics of how and when RFID can
Basics of today's RFID
RFID was initially developed as a method for remotely gathering data through tags or transceivers, either attached to or embedded in the object from which data must be obtained. These tags employ internal circuitry and antennas to emit a radio frequency wave that is secured and analyzed by an RFID readerwww.cechina.cn, and the system is often used for work-in-progress (WIP) in the industrial realm—tracking materials throughout the manufacturing process.
With its compact electronic design, RFID tags can come in virtually any housing style—from extremely small, embeddable devices to flat labels or stickers. In the industrial realm, RFID is often implemented within form factors that can be easily integrated into existing systems. For instance, manufacturers integrate RFID into sensor housings, because plant engineers are already aware of how sensors are best mounted on the plant floor.
www.cechina.cn, the product and its tag can be placed in virtually any orientation. Here控制工程网版权所有, the tag is mounted in the lower cornder of the metal carrier. " src="http://www.cechina.cn/upload/article/497be223-0065-4ec1-b491-54c89191e180/1.jpg">
Because RFID readers do not rely on line-of-site to obtain data from tagswww.cechina.cn, the product and its tag can be placed in virtually any orientation. Here控制工程网版权所有, the tag is mounted in the lower cornder of the metal carrier.
Legacy RFID operates at 125 kHz, but its modern incarnation typically adheres to the 13.56 MHz standard—making its operability considerably faster than older systems. Also, while many legacy RFID systems allow only static read-and-write operations, modern systems are capabl
