Innovations in Sensors such as proximity switches have been impressive. The packages are smaller, yet have longer ranges. Microcontroller-driven “teach-in” processes for precise sensor settings have replaced cumbersome and inaccurate potentiometer synchronization. Diagnostics have expanded to include such things as early warnings against dirt contamination.
Yet, to be able to fully use these new developments in diagnostic and parameter information控制工程网版权所有, they must be made available to the automati
Until now控制工程网版权所有, the only way to communicate with “intelligent” proximity sensors is with a separate PC directly connected to them控制工程网版权所有, because this newfound intelligence stops at the interface. It goes no farther because there is no way for it to go. Modern automation systems do not have the benefit of standardized, bidirectional communication between the sensors and the control level.
As a result控制工程网版权所有, the sensor’s parameters must be configured directly by hand, either before delivery or during the commissioning phase of a new machine when it is installed.
And that’s exactly where the backup of these sensor parameters stays: on the PC that was used to commission them. It is easy to see the problems that will arise from this. If a sensor (or actuator) needs replacing, woe be it to the technician if he can’t find a copy of the parameter file. He’ll have to enter them all over again in the new devices.
What about sensor diagnostics? Few technicians want to leave their laptops connected to the sensors during operation, so continuous diagnostics are usually not available. While some sensors do provide a diagnostic output signalCONTROL ENGINEERING China版权所有, this requires a separate I/O line. Most end users understandably don’t want to double the amount of I/O wiring t
康耐视AI机器视觉缺陷检测全行业解决方案
2026 Raythink燧石红外热像仪有奖试用
