资讯 > 英文资料文献
Integrating Environmental Processes
作者:Rob McGreevy, Wonderware2009.01.05阅读 3931
  Environmental controls are a critical part of manufacturing and can be fully integrated into larger plant-wide control systems to leverage reporting and historian capabilities.
  With rising prices of forest resources控制工程网版权所有, producers have found ways to use lower cost raw materials while producing final products with higher levels of consistency and workability that professional builders want to keep projects profitable.
  One problem is that engineered wood products frequently use resins and adhesiv
es that outgas potentially harmful solvents and VOCs (volatile organic compounds). Plywood depends on phenol-formaldehyde adhesives for exterior grades and urea-formaldehyde resins for interior grade hardwood plywood. Oriented strand board (OSB), medium density fiberboard (MDF), and other hardboards use phenolic, urea-formaldehyde, and melamine-urea-formaldehyde resins as critical binders. For laminated and finger jointed products, resorcinol-formaldehyde and phenol-resorcinol-formaldehyde adhesives are typical.
  “Anybody in the wood products manufacturing business is using some kind of resin to bond the wood together,” says Chris Selph, account executive from Wonderware Southeast. “That’s where you get the byproducts such as methane and formaldehyde that have to be eliminated under the clean air act. (Clean Air Act of 1970.)”
  In production, process fumes are collected and treated using regenerative thermal oxidizers (RTO), biofilters, scrubbers, or other systems. While such abatement processes have often been thought of as add-ons to larger manufacturing systems, recently environmental compliance stages have been integrated more completely into the control platforms.
  Georgia-Pacific (GP) is a major player in the larger forest products industrywww.cechina.cn, producing lumberwww.cechina.cn, paper, chemicals控制工程网版权所有, and countless variations on these basic resources. The GP plant at Monticello, GA is one of the leading producers of thin MDF. Each day, the plant produces more than 690控制工程网版权所有,000 square feet of paneling
