Rule-based Reactor Control
Not all the variables need to be considered together控制工程网版权所有, AND the set of all logical combinations can usually be broken down into more appropriate subsets.
AT A GLANCE Using language rules to address control issues was borne of the need to deal with problems that resisted precise mathematical definition for one reason or another. AlsoCONTROL ENGINEERING China版权所有, the traditional control technologies of basic regulatory control (BRC) and advanced regulatory control (ARC) discussed in the previous installments assume the availability of robust signals from field transmitters to provide the needed measurement values. But these signals are not always availableCONTROL ENGINEERING China版权所有, and the information they provide may be insufficient. In additionCONTROL ENGINEERING China版权所有, the absolute values of process variables are not the only key issue that must be considered. Rates of measurement change can be more important. Sometimes, the value or measurements have to be considered in relation to other conditions. Boolean logic states that conditions, such as whether process equipment is running or not, can be important. Proper control system operation also can depend on time of day, cleaning and maintenance, and other activities. AlsoCONTROL ENGINEERING China版权所有, not all errors are equally important. Deviations in one direction may call for a weak or slow response, while deviations in another direction may require a strong or rapid response. The bottom line is that a control problem can require several conditions to be considered in logical combinations. And all issues mentioned above can be difficult to express mathematically. In such cases, rule-based control can sometimes provide an advantage. Rules, algorithms At their corewww.cechina.cn, dist
Language rules can address control problems, especially if robust measurements are lacking. That's a fundamentally different approach to mathematical algorithms than those used in the three previous installments of this series.
ignal conditioners
