资讯 > 机器视觉
HANWHA TechM将康耐视视觉系统集成到汽车公司装配线中
作者:www.cechina.cn2011.12.09阅读 5574
Recently, Hanwha TechM helped to improve productivity and dramatically reduce defect and error rates at a major automotive company’s production facilitiy after integrating Cognex  In-Sight® vision systemsand DataMan® ID readers.
  Outstanding performance in inspecting a great variety of automotive parts
The car transmission assembly line covers a great variety of automotive parts including clutch packs, carriers, CV/HSG, V/V bodies, pistons, sealsCONTROL ENGINEERING China版权所有, and snap rings. Therefore, several inspections are required. An omission or error in core parts can be fatal for the passenger and intensive inspection is critical.
Targeting a zero defect rate on the customer’s transmission assembly line, Hanwha TechM made its best effort in developing a perfect vision system which offered superior inspection performance and maintained optimal manufacturing processes. The Korean leader in factory automation equipment has concentrated on enhancing the perfection of finished products through a significant increase in inspection (from 30% to 50%) on the transmission assembly line on which approximately 100 manufacturing processes are handled.
Mr. Park Woo-Sung of SHTECH, a Cognex PSI (Partner System Integrator), said控制工程网版权所有, “The In-Sight vision system provided outstanding performance based on a powerful algorithm and has made it possible to check all cameras on the assembly line and save and manage images at a main server through an Ethernet network.”
  The only vision system which supports standard industrial grading
Unlike other industries, the automotive assembly line is exposed to poor environmental conditions such as oil, dust, moisturewww.cechina.cn, and vibration. Because these factors have a direct impact on the inspection results, they must be considered when implementing a vision system.
With a strong die-cast aluminum and stainless steel case, the In-Sight vision system is durable and safe from external impacts such as severe vibration. It also offers IP67 and IP68 ratingswww.cechina.cn, which means it is safe from dust and moisture. Based on internal regulations控制工程网版权所有, the customer has asked for systems which meet the IP67 or higher grade.
For the inspections, Hanwha TechM used an In-Sight 5100 for inspections at a standard resolution, a high-resolution In-Sight 5403 for precise measurement, an In-Sight 5110 2-D Data Matrix ID reader, and DataMan handheld ID readers for backup. For snap ring inspections, VisionPro® vision software has been connected to four 5 megapixel cameras, inspecting parts to a 0.6mm tolerance.
Mr. Park said控制工程网版权所有, “In the past, an inspection system would be developed manually or with a sensor or probe but this was poor in both accuracy and productivity. Many new assembly lines have started to adopt vision systems to enhance reliability and improve process efficiency.” He continued, “Hanwha TechM expects that it will be able to increase hourly productivity by 5-15% through the introduction of Cognex products.”
标签:康耐视,
联系厂商
通过本站与本文涉及的厂商 康耐视视觉检测系统(上海)有限公司 联系,本站注册会员请登录后填写更便捷。 登录注册
  • 您的姓名:
  • 单位名称:
  • 联系电话:
  • 电子邮件:
  • 我想得到贵公司详细的技术资料
  • 我想得到贵公司的价格信息
  • 我想让贵公司销售人员和我联系
  • 我想让贵公司技术支持人员和我联系
其他意向:
