The company asked CI Vision (AuroraCONTROL ENGINEERING China版权所有, IL), for a new visio
The base model of the Pro Series system has two cameras in steel housings connected via the GigE Vision camera interface standard. Up to four cameras can be installed控制工程网版权所有, and the vision system is controlled either by a custom-built PC or Matrox 4Sight X industrial PC. The CIVCore software that controls the image acquisition and inspection tasks is built from the Matrox Imaging Library (MIL).
CI Vision's label image acquisition and inspection software is built from the Matrox Imaging Library
To inspect a product batchwww.cechina.cn, an operator sets up the inspection type on a touchscreen. When an image is acquiredwww.cechina.cn, normalized grayscale correlation is used to determine the presence or absence of the label itself, as well as the location of the label’s region of interest (a bar or matrix code, or a lot number). Code 128 bar and two-dimensional data matrix codes are read by MIL’s code module for correctness. The CIVCore’s OCV moduleCONTROL ENGINEERING China版权所有, which is built from MIL’s pattern matching and image processing modules, reads text-based lot numbers and label control numbers.
The Pro Series system features an optional tool that detects if the same label appears on the front and back of the product. The system uses the search model from the presence/absence feature to determine which label is in front of Came
