资讯 > 英文资料文献
R. Stahl's compact field device couplers suited for Zone 2 hazardous areas
www.cechina.cn2011.05.09阅读 2509
With its new Series 9410 Zone 2 Ex n field device couplersCONTROL ENGINEERING China版权所有, R. Stahl extends its already wide range of Fieldbus installation material. The new, compact and cost-eFFective couplers are available with 4CONTROL ENGINEERING China版权所有, 8www.cechina.cn, and 12 spurs. They are suitable for Zone 2 hazardous area installation and connection to field devices using Ex ic, Ex nL, or Ex nA type protectionCONTROL ENGINEERING China版权所有, and for Zone 1 Ex d and Ex m equipment as well.
All couplers feature detachable screw terminals with locking screws and a red LED for each spur for failure indication. R. Stahl Power Management is also available with these couplers. Softstart function significantly reduces inrush current during startup of a fieldbus segment by energizing one fieldbus device after the other, lowering energy consumption more than 50%. The short-circuit switch-off function de-energizes fieldbus devices in a short-circuit situation so that even with multiple short circuits energy consumption is limited to one device only.
Series 9410 Zone 2 Ex n Field Device Couplers come with an extensive range of installation materials and enclosures, including GRP and stainless steel material for customized solutions.
For more informationCONTROL ENGINEERING China版权所有, visit the R. Stahl website.
标签:FF,Fieldbus,
