当前位置:资讯 > 英文资料文献 > 正文
Measuring Pressure in Steam Sterilizers
发布时间:2009-03-27     作者:Andrew Sim, Baumer, U.K
摘要:Keeping a lid on large sterilizers and autoclaves depends on careful pressure monitoring, but a wide temperature range and hygenic mounting requirements makes it a challenge.
act are made of 316L / 1.4435 stainless steel and all materials, including the white oil used as fill liquidCONTROL ENGINEERING China版权所有, are compliant with U.S. FDA standards.
  For more standard pharmaceutical sterilizer applicationswww.cechina.cn, each unit uses two pressure transmitters with a range of 0-4 bar (0-60 psi). An additional unit with a pressure range of 0 to 6 bar (0-90 psi) is inserted into the steam supply pipe.
  Belimed Sauter has evaluated a variety of pressure sensorswww.cechina.cn, but given this difficult and critical applicati
onwww.cechina.cn, the company prefers to use what it knows works. Rolf GermannCONTROL ENGINEERING China版权所有, head of logistics for the company says, “We decided to use Baumer products because they offer high accuracy and stability even in environments with big temperature variations like our sterilizers.”
标签:control,
版权声明:版权归中国控制工程网所有,转载请注明出处!
