Avoiding the need for hard wiring, the latest terminal blocks provide safe, secure connections with greater ease. Terminal block designs also offer more flexibility控制工程网版权所有, space savings, accessory options, and integrated intelligence compared to prior designs.
Although they are often overlooked, terminal blocks are a critical part of the electrical control system, says TJ Landrum, product manager for DIN logic products, Eaton Corp. Important time and space-saving technologies are in wider use, Lan
Other available control and protection features include fuse terminal blockswww.cechina.cn, circuit breaker modules, diode terminal blockswww.cechina.cn, and disconnect blocks. These “help integrate more functionality into a compact DIN rail assembly,” Landrum says.
In the last five years, Phoenix Contact also has observed greater IDC acceptance, and growth in what it calls hybrid terminal blocks. Larry FreelandCONTROL ENGINEERING China版权所有, Phoenix Contact Clipline product marketing manager, says, “In our testing we’ve found IDC can be up to 80% faster than using a screw clamp connection with a manual screwdriver and ferrules. It is also up to 70% faster than spring-cage with ferrules and 50% faster than spring-cage without ferrules.”
Hybrid designs feature different connection technologies (such as IDC-to-screw, IDC-to-spring, and screw-to-spring connections) on each side of the terminal block. These are typically used when the machine builder or panel builder is not installing field wiring. The panel builder may use IDC inside the panel while building it and use screw connection for the conductors that come from the outside, which may be favored by the field installer控制工程网版权所有, Freeland says. Other flexible, hy
